I want these separate lines as a one line.
I also want to connect those blank spaces between lines (if possible).
When I List those different objects it will show like one object.
List will show length and others information as a one object.
How can I make this possible in TrueView?
Please guide me...
your help is badly needed...
Banna
banna.kbet@gmail.com
Solved by pendean. Go to Solution.
Can you please share AutoLISP code for measuring the whole line including blank space distance....
Now I can get total length of including line, arc but I also want to include the blank space distance.
Please help me, now I am using AutoCAD.
TIA
Banna
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
