I installed DWG TrueView 2014 on Windows 7 (64 bits) OS;
Instalation succesfull
Tried to open it => OK
Tried to open a dwg file => ERROR :
LoadLibrary failed with error 126: The specified module could not be found.
Any ideea what can be wrong ?
I found the solution on internet :
and it WOOOOOOORKS !
Thnks INTERNET !
Hello!
I normally do not respond to anything in the internet, but I am breaking my rules because I found this to work for "LoadLibrary error 126: can't find module" error, and it may help others the same way someone else helped me.
I have:
HP dv7 laptop with amd hd graphics
Win 7 64
I am running:
SW premium 2014
When I double clicked the SW icon to enter the program, it would give me the "error 126" consistently, and nothing I did in terms of unistalling drivers, reinstalling, whathaveyou, ....nothing worked!
I searched the internet, and I found that people running some Adobe programs are having the same problem (error 126), and one person posted the following in their forum (paraphrasing):
"go to Start button >> type "cmd" at the search box , and hit enter >>
this will take you to a shell "dos black box" (in lack of a better description),
make sure your windows account has you as an administrator, otherwise this will not work!,
at the dos prompt type: "cd /d c:\windows\system32" and hit enter,
(this changes the directory to c:\windows\system32),
from here on you need to follow the indications given by the Adobe user in the following youtube video:
http://www.youtube.com/watch?v=C6QPp3wM_QE
In case you can't find the youtube video, the Adobe user recommends doing the following:
For 64-bit systems:
If your GPU has a "M" suffix, use this copy command at the dos command prompt to copy this file:
"copy atio6axx.dll atiogl64.dll"
If it diesn't have that suffix, use this copy command at the dos command prompt to copy this file:
"copy atio6axx.dll .dll"
For rare cases, use this copy command at the dos command prompt to copy this file:
"copy atiogl64.dll .dll"
Just in case someone out there is running SW 2014 on a HP dv7 Win 7 machine w/ AMD HD graphics card, the following is the syntax that did the trick for my system:
c:\Windows\system32\copy atio6axx.dll atiol64.dll" and the system returns "1 file(s) copied." response.
This worked for my setup and I am now able to work with my CAD system.
I hope this works for you!
Cheers
