DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
inserted metric blocks created in millimeters get scaled 25.4
2 REPLIES 2
219 Views, 2 Replies
Some help please. When inserting blocks that I created in millimeters, these blocks get scaled up 25.4. All units are set in millimeters in the source file and the target file. The INSUNITSDEFSOURCE and the INSUNITSDEFTARGET ARE SE TO 1 in the source file and target file. There is no mention at all of the imperial system in both of these files and yet all of these blocks get scaled up by a factor of 25.4 which is the conversion factor when scaling from INCHES to MILLIMETERS. I even checked the acadiso.dwt which is created by Autodesk. I am using Acad 2017, and I don't know if this is a coincidence, but my problem started when I installed this version of Acad and for some reason it has effect even Acad 2015.
Thanks for reading this.
2 REPLIES 2
you are in a wrong forum....
This is only viewer...
Cheers
Banna
Sorry, it was the first post
