DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
files don't open
2 REPLIES 2
jdn4u2
820 Views, 2 Replies
files don't open
True view 2025. I try to open dxf files. I get no error like can't find path etc. But nothing displays in the model or layout pages. I use the same file with their online viewer and get results, so the file isn't empty. I just installed this yesterday, so user error isn't out of possibilities.
2 REPLIES 2
pendean
in reply to: jdn4u2
Unless you plan on sharing your DXF files here, not sure anyone can provide you with much guidance on what to do.
The online viewer may use a different conversion/viewer tool: DWGRUEVIEW uses whatever is built into AutoCAD and that can be very picky and rejects DXF file that are not 100% in compliance with Autodesk's DXF code.
There are dozens of free and low cost DXF viewers online, help yourself if DTV fails to meet your needs regularly.
fromhlukhiv
in reply to: jdn4u2
@jdn4u2 wrote:
True view 2025. I try to open dxf files. I get no error like can't find path etc. But nothing displays in the model or layout pages. I use the same file with their online viewer and get results here, so the file isn't empty. I just installed this yesterday, so user error isn't out of possibilities.
I've had similar issues before. Sometimes resetting the workspace or updating the software can help . Have you tried checking if there are any pending updates for TrueView 2025?
