DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
File opening problems
4 REPLIES 4
gurkan_durukal
89 Views, 4 Replies
I have two problems with DWG TrueView software:
1. DWG TrueView closed. When I double-clicked on a DXF file in Windows Explorer, it opens in two different tabs which is unnecessary.
2. Imagine that set of DXFs were opened in DWG TrueView. When I clicked on another DXF, it opens; but it hangs the tab of last file from the set. I have to click the last tab for viewing the last opened file. It makes me confused especially with the bunch files which has similar geometry.
Above problems were seen previous versions of your software.
I hope they will be fixed future versions. Thank you in advance,
Bye.
4 REPLIES 4
pendean
in reply to: gurkan_durukal
1. Autodesk wants us to open the program first, then the file. Go figure.
2. Same issue as above by chance, aka you are not opening a DXF file from inside DTV?
What year version of DTV are you using? and OS?
Have you tried grabbing an older or newer version to test?
gurkan_durukal
in reply to: pendean
1. I accept the solution for the first problem.
2. I prefer to open DXFs from Windows Explorer because navigation is easier than DTV interface. This issue pops up rarely. I am using DTV 2025 V. 154.0.0 and OS is Windows 11 Pro 24H2. I saw that issue in DTW 2019 and 2022.
Bye.
2. Imagine that set of DXFs were opened in DWG TrueView. When I clicked on another DXF, it opens; but it hangs the tab of last file from the set. I have to click the last tab for viewing the last opened file. It makes me confused especially with the bunch files which has similar geometry. --> That issue is frequent; I think DTV is unstable regarding "open a file"... @pendean
pendean
I have no such issues but I'm not using DTV2025 (it adds no value to older versions since 2022).
Try an older version of DTV (2024, 2023?).
