I have two problems with DWG TrueView software:
1. DWG TrueView closed. When I double-clicked on a DXF file in Windows Explorer, it opens in two different tabs which is unnecessary.
2. Imagine that set of DXFs were opened in DWG TrueView. When I clicked on another DXF, it opens; but it hangs the tab of last file from the set. I have to click the last tab for viewing the last opened file. It makes me confused especially with the bunch files which has similar geometry.
Above problems were seen previous versions of your software.
I hope they will be fixed future versions. Thank you in advance,
Bye.
1. I accept the solution for the first problem.
2. I prefer to open DXFs from Windows Explorer because navigation is easier than DTV interface. This issue pops up rarely. I am using DTV 2025 V. 154.0.0 and OS is Windows 11 Pro 24H2. I saw that issue in DTW 2019 and 2022.
Bye.
2. Imagine that set of DXFs were opened in DWG TrueView. When I clicked on another DXF, it opens; but it hangs the tab of last file from the set. I have to click the last tab for viewing the last opened file. It makes me confused especially with the bunch files which has similar geometry. --> That issue is frequent; I think DTV is unstable regarding "open a file"... @pendean
