I just installed DWG Trueview 2017, but it doesn't work.
I double click the icon but the program does not launch, and there is no error message jumped out.
I unstand there are some similar posts in the comuunity forum, and I have tried:
1) un-install/re-install the package, after modify the WIN registry editor correctly.2) add /nohardware in the end of the command to launch the software.
but neither of them works.
Note that I have also tried to install this tool on two different computer, but I still cannot launch it.
I wonder if there is someone who has met this issue recently, and has some brilliant way to solve the problems.
Cheers,
Nai-Yuan
Hi Pendean,
Thanks a lot for your reponse.
I am using Window 7.
I did restart the PC several times, but the problem still exists.
Do you mean Performance Monitoring? I tried the tool but it seems nothing wrong.
The usage of processors/memory does not change much when I launch the TrueView application.
Additionally, from Windows Task Manager, I can see dwgviewr.exe appears as soon as I double clilk the trueview icon.
However it disappears without any error message, after 1 or 2 seconds.
Nai-Yuan
Do d
Hi Pendean,
Have you had any luck in launching DWG Trueview??
I am running W8.1 and having same problems as you list. There was no systems criteria listed for the app before I downloaded. I have a few older plans I want to print so I might have to find someone with ACad who will hard copy them for me.
Hallo,
Thank you for your answer.
But, after I have done what it is written in that link, still nothing changed !
Did stopped the Antivirus and the firewall !
Performed a clean uninstall with MicrosoftProgram_Install_and_Uninstall.meta.diagcab and then reinstalled !
To be mentioned that other similar programs are working (DWG see 2017)
Made update for the graphic card,
All the updates for windows 10 are installed
When my user tries to launch TrueView I see these two errors in the event log:
Log Name: Application
Source: .NET Runtime Optimization Service
Date: 2/6/2017 8:17:25 AM
Event ID: 1101
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Fluor-Spare.rwcb.local
Description:
.NET Runtime Optimization Service (clr_optimization_v4.0.30319_32) - Failed to compile C:\Program Files\Autodesk\DWG TrueView 2017 - English\accoremgd.dll because this image is a 64bit assembly; try using 64bit ngen instead.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name=".NET Runtime Optimization Service" />
<EventID Qualifiers="0">1101</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2017-02-06T13:17:25.000000000Z" />
<EventRecordID>20129</EventRecordID>
<Channel>Application</Channel>
<Computer>Fluor-Spare.rwcb.local</Computer>
<Security />
</System>
<EventData>
<Data>.NET Runtime Optimization Service (clr_optimization_v4.0.30319_32) - Failed to compile C:\Program Files\Autodesk\DWG TrueView 2017 - English\accoremgd.dll because this image is a 64bit assembly; try using 64bit ngen instead.
</Data>
<Data>C:\Program Files\Autodesk\DWG TrueView 2017 - English\accoremgd.dll</Data>
</EventData>
</Event>
Source: Application Error
Date: 2/6/2017 8:17:59 AM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Description:
Faulting application name: dwgviewr.exe, version: 27.0.301.0, time stamp: 0x5811c6dc
Faulting module name: acdb21.dll_unloaded, version: 0.0.0.0, time stamp: 0x5811a6b3
Exception code: 0xc0000005
Fault offset: 0x000007fee305e1a4
Faulting process id: 0x3f8
Faulting application start time: 0x01d2807b6c89288a
Faulting application path: C:\Program Files\Autodesk\DWG TrueView 2017 - English\dwgviewr.exe
Faulting module path: acdb21.dll
Report Id: ad9374c3-ec6e-11e6-a0db-b083fe83e056
Event Xml:
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<TimeCreated SystemTime="2017-02-06T13:17:59.000000000Z" />
<EventRecordID>20131</EventRecordID>
<Security />
</System>
<EventData>
<Data>dwgviewr.exe</Data>
<Data>27.0.301.0</Data>
<Data>5811c6dc</Data>
<Data>acdb21.dll_unloaded</Data>
<Data>0.0.0.0</Data>
<Data>5811a6b3</Data>
<Data>c0000005</Data>
<Data>000007fee305e1a4</Data>
<Data>3f8</Data>
<Data>01d2807b6c89288a</Data>
<Data>C:\Program Files\Autodesk\DWG TrueView 2017 - English\dwgviewr.exe</Data>
<Data>acdb21.dll</Data>
<Data>ad9374c3-ec6e-11e6-a0db-b083fe83e056</Data>
</EventData>
</Event>
I received the same error message after installing DWG TrueView 2018.
Thanks, The problem has gone away. I think I uninstall DTV 2015 after installing 2018. I think I cleared it up by going to uninstall, selecting repair and then rebooting.
