I guess to reproduce my problem, we are using 2007: Create a DWG drawing in AutoCad Mechanical Desktop, using Layout Mode. Now Create a similar DWG file using AutoCAD.
Do not setup and Page Setups for these DWG, since my problem is with importing Page Setups from a "plot template"
Create the DWT drawing called Plot Template using AutoCad.. this is the drawing that will have 5 Page Setups.. Give it Page Setups called A, B, C, D and E.
Now open the DWG created with AutoCAD using DWG TrueView. File -> Plot.. Page Setup, Import. Select the DWT file, and then select A template (or any I guess). The settings from the DWT File Load fine.
Now open the DWG File created with Mechanical Desktop using True View. The viewer will go to Layer Mode, since that is where the drawing is (whether something is drawn in Model Space or not).. File -> Plot. Page Setup, Import. Select the DWT file, then a template..
---> Nothing happens! <---
Okay, go DWG TrueView opening the MechDesktop DWG again, and flip the view at the bottom to Model. Now import the Page Settings again from the Plot Template. The settings load.. however, our drawings are in Layout Space.
One thing I've tried since yesterday is AutoDesk Design Review.. This Plot Dialog is using mostly Radio Buttons instead of CheckBoxes.. so my AutoMate program will be consistant using this program to plot DWGs whether they were created in Layout Space or Model Space.
The test I didn't get to try was creating a DWT file from MechDesktop, and creating Page Setups for Layout Space.. Then in TrueView's import page space, trying to import that for both AutoCad/MechdeskTop DWG files.
Did I explain that ok?
