Hi.
I have scheme with pipilene 50 km long ( it's made in autocad, but viewing with dwg trueview 2013). I need to measure distance in specified points, but distance between them too long and i need to scroll down screen but i can't. Is it possible to measure distance between multiple points and scroll the screen at the same time?
Yes it is possible...
1. Click measure----> Distance
2. Select 1st point
3. Write Multiple in your keyboard
4. Select other line
5. If you need to scroll then click PAN option in your drawing
6. After panning press ESC button in your keyboard
7. then again click point to measure distance
8. when you finish clicking point then press enter
I hope you can solve your problem.
If successful do not forget to mark as a solution.
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
