I am self thought and use 2000 release which worked beautifully until now.
Assuming the command line and the command window are separate entities I suddenly lost the entire command window and cannot recall how it might have happened.
I tried to grab it around the status bar in case I had hidden it behind the bar but couldn't find it there or anywhere else.
Tried to use the text window but when I tried to drag it near the status bar ( the correct place I read ) the text line is hidden because the title of the text window is the only place to use when dragging the window whatever is beneath it ( the command line in this case ) is hidden. It seems that the text window is not dockable and when I try using it as a floater it disappears as soon as the command is entered.
Trying to enter text or tools is useless without the command window given what I've seen so far.
Any thoughts?
B. R. May
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time
