DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Clarification needed: DWG TrueView Security Update ADSK-SA-2024-0021
3 REPLIES 3
linbud
257 Views, 3 Replies
Hi everyone,#
I’m hoping someone here can help, as I haven’t had much luck with Autodesk Support on this...
The security advisory ADSK-SA-2024-0021 (https://www.autodesk.com/trust/security-advisories/adsk-sa-2024-0021) says the vulnerability in DWG TrueView is fixed in version 2025.1.1. But after downloading and installing the latest version from the official site, the version on my system shows as 25.0.154.0 (and in the app as Product Version: V.154.0.0).
So I’m confused:
  • Does version 25.0.154.0 actually include the security fix?
  • If not, where can I get the correct version mentioned in the advisory?
If anyone has run into this or knows what’s going on, I’d really appreciate some clarity!
Thanks a lot!
Linnéa
3 REPLIES 3
pendean
in reply to: linbud
linbud
in reply to: pendean
Hi pendean,
Thank you so much for your response and for clarifying the versioning system for AutoCAD 2025.1.1! That’s really helpful. I honestly don’t know why the support team couldn’t provide me with that information.
Just to make sure I’ve got this right: Does the same logic apply to DWG TrueView? Since it’s essentially a "light" version of AutoCAD, I’m assuming that "V.154.0.0" in DWG TrueView also corresponds to the 2025.1.1 version.
Thanks again for your help!
Best regards,
linbud
pendean
in reply to: linbud
Yes, the same.
