After installing the 2015 dwg trueview 64bit, I try to start the program and I get an error message 0xc000142. Traced it to vc64loader.dll, renamed the file, everything works great until I reboot and I get that error message again. This is an issue because I do not have admin rights and I need to get the IT tech to rename the file each time.
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
