DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
can't open 2015 dwg trueview
3 REPLIES 3
956 Views, 3 Replies
After installing the 2015 dwg trueview 64bit, I try to start the program and I get an error message 0xc000142.  Traced it to vc64loader.dll, renamed the file, everything works great until I reboot and I get that error message again.  This is an issue because I do not have admin rights and I need to get the IT tech to rename the file each time.
3 REPLIES 3
pendean
Admin rights required to use the software.
ukdxb012
Have you tried increasing the rights to user permissions to the Trueview install folder. Sometimes you can apply this instead of giving the User Local Admin Rights.
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
