DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Batch Plot multiple DXF to PDF
1 REPLY 1
giuseppeballardin
132 Views, 1 Reply
Hi, I'm quite a newbie using Trueview, I'd  like to publish using batch plot mutiple DXF files, converted to PDF, at one time, and I'd like to load and set a page setup for all pages (monochrome and other specifics).
Is it possible?
When I load the DXF files I'm encountering this error now: "Layout not initialized"
1 REPLY 1
pendean
in reply to: giuseppeballardin
To avoid the issue:
1. Start PUBLISH command from a DWG "template" that is not part of the publish set, but is configured with all your possible sheets and plotter options.
2. Bring in all the other drawings/tabs to be published.
3. Import the pagesetup desired from that "template" file (in your case, one set up for exacting desired output).
4. PUBLISH.
