Hello!
I've recently run into some troubles using AutoCAD 2017 Educational Version. When I try to open recent files, I get a dialogue box saying that the file is "not valid". Additionally, when I open older ones, they come up with a lock icon next to the file name, and when I try to save them, it says they are "write protected". I have tried some of the previously posted suggestions and saved them under different names, as well as right clicking the files in explorer, going to "properties" and making sure the files are not "read only". I think the problem originated when I tried to set up the autosave function under the command "wautosave" and "savetime". I set the save time to 10 and wautosave to 1. I've since tried to undo both commands, but to no avail. Any input is much appreciated. Thank you!
Following up on your thread, were you able to find a solution or a workaround?
I think you posted accidently on the wrong board. I'd be happy to try and help.
Please post back in the thread with updates.
Thanks.
