Hallo.
I have made a SCCM deployment of Dwg Trueview, but on some machines i get an error on the startup screen. Testet on several machines now, one with windows 10 vent ok. One windows 8.1 went ok.
But then i testet on some other win 8.1 machines and 3 of them get an error message when the program launch.
"FETAL ERROR: Unhandled E043435h Exception at a04f8a5ch"
I have used theese options : http://blog.techygeekshome.info/2016/06/deploy-autodesk-dwg-trueview-2017-using-sccm/
Following up on your thread, were you able to find a solution or a workaround?
Are you still running into this issue with starting DWG TrueVIew?
Post back with any updates!
Thanks.
follow this, I hope it will be solved...
The article suggested by @ banna.kbet would be suggestions I would recommend.
Did the article help?
Are you still having a problem?
