Trueview Script to plot DWG files fails for some
Message 1 of 1
I'm using a script for TrueView to plot a dwg file into pdf that works for some files but fails to others that I'm able to plot manually. I think some configuration is missing on the script. I've already been through the PLOT documentation but haven't found the meaning of any command line on script could you please send to me those?
I'd like to send dwg file that's failing to convert so you can test this script but I couldn't find the option to set this Post as private.
PLOT
Y
Model
DWG To PDF.pc3
ISO A4 (297.00 x 210.00 MM)
M
L
N
D
F
0.00,0.00
No
Yes
As
C:\plot.pdf
N
Y
QUIT
Replies (0)
