DWG Trueview multi-user installation
Ariën
Ariën
It would be great if DWG Trueview contains a function to export and import user profiles with e.g. settings for plotters, plotstyles and default locations to open dwg's from.
Companies with hundreds of employees where there is a huge demand to just view and/or print dwg's would be glad if Trueview offers the possibility to export/import an *.arg profile just as is normal in AutoCAD.
pendean
Community Legend
Community Legend
@Ariën That ability is exclusive to full AutoCAD only (not even low-end LT versions have it): the free viewer is never likely going to do what you ask since it will rob sales away from their premium software packages.
There is not likely to be a provided-by-autodesk free backdoor solution these days, maybe 30-years ago when their were more desperate for customers.
Ariën
Not implementing such functionality might rob their premium software packages, but large companies might switch to non Autodesk alternatives, that will rob them from more then just premium software packages, they might loose customers.
manieshkumar.suresh
Currently DwgTrueview is free application as mentioned by @pendean and most of feature you mentioned is available in AutoCAD LT and AutoCAD full version.
DWG TrueView is limited to viewing, publishing, and converting DWGs. You cannot use it to change or save drawing files. Other free products available from the Autodesk website that might be of interest to you include the following:
  • Autodesk Design Review. Using the DWF, DWFx, and PDF formats, you can review, mark up, save, and print drawing files created with AutoCAD-based products.
  • Autodesk AutoCAD mobile app. You can open, view, and work with CAD drawings and DWG files on the go from your smartphone or tablet—anytime, anywhere.
  • AutoCAD web app. You can open, view, and work with DWG files in AutoCAD anytime, anywhere.
  • Autodesk A360 Mobile App. You can open, view, and work with 3D and 2D DWG/DWF files, and Autodesk Revit and Autodesk Navisworks software files on a mobile device.
Using DWG TrueView, you can:
  • Open and view DWG and DXF files
  • Obtain geometric information from drawings such as distance, mass, and volume
  • Plot DWG files to a plotter
  • Create DWF, DWFx, PDF, JPG, and PNG files from DWG files
  • Publish sets of drawings or sheets to a plotter, or DWF, DWFx, and PDF files
  • Convert DWG files forward and backward with versions as early as AutoCAD Release 14
You do not need to know AutoCAD to use DWG TrueView, but it is helpful to understand how AutoCAD Layers work, and how to use the page setup, plotting, and publishing dialog boxes.
Supported File Formats
Drawing information created in AutoCAD-based products can be saved or exported to the following file formats.
  • DWG drawing file format is the native file format for AutoCAD-based products. With DWG TrueView, you can open all drawing files regardless of version, and you can save to DWG file formats as early as AutoCAD Release 14.
  • DXF (Drawing Interchange Format) is a published file format used for interoperability between Autodesk products, third-party applications, and non-Autodesk products.
  • DWF (Design Web Format) and DWFx (DWF for Windows XPS Viewer) are ideal for sharing drawing file information with team members, vendors, clients, subcontractors, and customers that do not have access to an AutoCAD-based application.
  • PDF (Adobe’s Portable Document Format) is one of the most commonly-used formats for sharing drawings with team member and clients.
Article - https://help.autodesk.com/view/TRUEVIEW/2026/ENU/?guid=GUID-3B781BF9-BE26-4E33-854E-BE5C6BCF8243
I request you to submit the feedback here - Sending Product Feedback to Autodesk
Maniesh Kumar Suresh
Escalation Lead
If this information was helpful, please use the Accept as Solution function — it helps other users.
