DWG TrueView Batch Plotting Issue
Need some advice.
Our shop has 2 main computers, each has DWG TrueView installed with the latest version. I have followed all the correct steps to batch all .dwg files on both. Only one computer will not print anything in Batch. Plot only works fine. I will use the same printing template. All the information to the printer is correct, and both are set up identically on both computers.
What would possible cause this?
pendean
Community Legend
Community Legend
Most likely you missed something: could be a flaw in the pagesetup, or selecting a different pdf or dwf driver, or the driver it aims for is not correct.
PLOT allows you to correct many things, PUBLISH does not, so dig a little deeper.
