DWG Trueview 2014
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I have failed to find how to log a request direct to AutoDesk so will try here.
Our Setup
AutoCAD 2013
AutoCAD Raster Design 2013
DWG Trueview 2013/14
A lot of the time we work with hybrid drawings and a common problem we would get is AutoCAD Raster design could not save the hybrid drawing and would create a temp file.
Nobody could work this out but I have discovered the problem.
If a CAD/Hybrid drawing is being viewed by someone through DWG Trueview and another user is editing that some drawing in AutoCAD and trying to save the hybrid image autodesk will not allow this due to someone viewing the same drawing in DWG Trueview.
I have tried and tested this theory many times and it is the cause of the problem.
If the user viewing in DWG Trueview closes the drawing and the user in Autodesk trys saving the hybrid drawing all works fine.
Any AutoDesk people out there know of this issue?
Are there solutions?
Why does this happen since DWG trueview is a read only program?
Are there any solutions (and no I we cant find the person viewing the drawing each time as there are hundreds of users.)
thanks
Simon
