dwg converter
I am new to dwg trueview. I have opened up a cad drawing from CAD details, and I want to convert this to a 2004 dwg. I see up in the upper left tool bar, there is a button to convert, and I also see the different versions one can convert to. What I cannot figure out, is how to add the cad drawing I just opened to the window, that says add files. The button is inactive at the bottom that says convert, probably because I cannot add the file in the first place.
I work on a very old and archaic cad system, called AutoSketch 10. This is what I use, and it works for me. I cannot at dwg drawings from others, unless it is usually a 2007 or older. In this case, I want to convert a cad detail, save it as a 2004, or 2007, in which case, I can open it with Autosketch 10.
Thank you
