Common Language Runtime detected an invalid program
GilesPhillips
Message 1 of 1
GilesPhillips
I have a colleague with DWG trueview 2015 (on a window7 32bit laptop) which produces the above error. Full transcript from the debug session below.  Apparently he has asked our IT dept to fix it, and they've done a re-install with no sucess.
Anyone got any suggestions?  Thanks..
Debug:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.InvalidProgramException: Common Language Runtime detected an invalid program.
   at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.17379 built by: FXBETAREL
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Acdbmgd
    Assembly Version: 20.0.0.0
    Win32 Version: 20.0.51.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/DWG%20TrueView%202015%20-%20English/AcdbMgd.DLL
adui20
    Assembly Version: 0.0.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/DWG%20TrueView%202015%20-%20English/adui20.DLL
AdUiPalettes
    CodeBase: file:///C:/Program%20Files/Autodesk/DWG%20TrueView%202015%20-%20English/AdUiPalettes.DLL
WindowsBase
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
AdApplicationFrame
    Win32 Version: 5.2.8.100
    CodeBase: file:///C:/Program%20Files/Autodesk/DWG%20TrueView%202015%20-%20English/AdApplicationFrame.DLL
AdWindows
    Assembly Version: 5.2.10.200
    Win32 Version: 5.2.10.200
    CodeBase: file:///C:/Program%20Files/Autodesk/DWG%20TrueView%202015%20-%20English/AdWindows.DLL
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Aero
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
    CodeBase: file:///C:/Program%20Files/Autodesk/DWG%20TrueView%202015%20-%20English/accoremgd.DLL
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Acmgd
    CodeBase: file:///C:/Program%20Files/Autodesk/DWG%20TrueView%202015%20-%20English/Acmgd.DLL
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/DWG%20TrueView%202015%20-%20English/AcWindows.DLL
AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/DWG%20TrueView%202015%20-%20English/en-US/AcWindows.resources.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/DWG%20TrueView%202015%20-%20English/AcCui.DLL
WindowsFormsIntegration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationUI
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Windows.Forms
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework-SystemXmlLinq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AcLayer
    CodeBase: file:///C:/Program%20Files/Autodesk/DWG%20TrueView%202015%20-%20English/AcLayer.DLL
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/DWG%20TrueView%202015%20-%20English/en-US/AcLayer.resources.DLL
AsdkPublishAPI
    CodeBase: file:///c:/program%20files/autodesk/dwg%20trueview%202015%20-%20english/asdkpublishapi.arx
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
PresentationFramework-SystemCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
ACad, MEP, Revit, 3DS Max
Replies (0)
