Plotting DWG to DWFX
Message 1 of 8
We're thinking of batch convert a huge DWG archive to DWFX, to offer our users the possibility of seeing drawings in IE11.
Searching Google did not result in a tool to do the job. How would you do this? How do other companies do this? Maybe use a 2 step way, first convert to DWF, then to DWFX?
Kind regards,
Pauline Berens
Replies (7)
Message 2 of 8
rendermaster
how about the command:_EXPORTDWFX
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 3 of 8
pendean
Community Legend
Community Legend
You can PLOT to DWFX from inside AutoCAD all day long: what's the challenge?
Message 4 of 8
not so easy if you have mac....
Message 5 of 8
Hi everybody,
I don't see a batch solution, how can I close this question? Thanks for your help.
Bye,
Pauline
Message 6 of 8
pendean
Community Legend
Community Legend
This is not a MAC software or forum...
Message 7 of 8
pendean
Community Legend
Community Legend
>>>...We're thinking of batch convert a huge DWG archive to DWFX...<<<
>>>>..I don't see a batch solution...<<<
In AutoCAD the command is called PUBLISH.
Message 8 of 8
papillrmWBY3V
Community Visitor
Community Visitor
In Autodesk's free Design Review application, use Save-As and, when prompted, change the file extension from .DWF to .DWFx. Or, use Autodesk's free DWG TrueView application to batch publish DWG files to DWFx files. AutoCad is NOT needed. The advantage of using the first method (Design Review instead of TrueView) is that Save-As retains all of the original .DWF file's text-searchable information. Unfortunately, using DWG TrueView to convert .DWG files directly to .DWFx files does not keep any text information.
