My key button is not working. PICKFIRST is set to 1 and noun/verb selection is on. Whats wrong?
If your keyboard key is not working in AutoCAD, there could be several possible reasons for this. Here are some troubleshooting steps you can try:
1. Check if the key works in other applications or programs. If it doesn't, then it may be a hardware issue with the keyboard itself.
2. Check if there are any conflicts with other keyboard shortcuts in AutoCAD. You can try changing the shortcut for the command or disabling conflicting shortcuts.
3. Check if the keyboard language is set correctly. Make sure that the keyboard layout matches the language that you are using in AutoCAD.
4. Try resetting AutoCAD to its default settings. This can be done by typing "OPTIONS" in the command line, going to the "Profiles" tab, and selecting "Reset to Default".
5. Try updating or reinstalling AutoCAD. It's possible that there may be a software issue causing the problem.
If none of these steps resolve the issue, you may need to contact Autodesk support for further assistance.
Thanks and Regards
Jayhar M J
