DWF
Installed DWFWriter: Can't print DWF
2 REPLIES 2
Tom.DiGregorio2DPCZ6
723 Views, 2 Replies
Installed DWF Writer for 2D 64 bit.
File Version 15.0.0.498
Product version 4.0.0.125
Windows 10 64 bit
Will create a DWFx but will not create a DWF.
The printing process seems to complete normally with no errors but no file is created.
[ The subject line of this post has been edited for clarity by @pendean Original: Can't print DWF]
Tags (1)
2 REPLIES 2
If you’ve installed DWFWriter but are unable to create DWF files, here are some steps you can try to resolve the issue:
  1. Check Installation: Ensure that DWFWriter is correctly installed on your system. You might want to reinstall it to make sure it’s properly set up.
  2. Set as Default Printer: Make sure DWFWriter is set as the default printer in your system settings when you’re trying to create a DWF file.
  3. Update Software: Verify that you have the latest version of DWFWriter installed, as updates often fix bugs and compatibility issues.
  4. File Permissions: Check the permissions of the folder where you’re trying to save the DWF file. You need write permissions to create files.
  5. Compatibility Mode: If you’re using an older version of DWFWriter on a newer operating system, try running it in compatibility mode for the OS it was designed for.
  6. DWFx Files: If you can create DWFx files but not DWF, it could be a software glitch or a setting issue within the DWFWriter properties. Check if there’s an option to toggle between DWF and DWFx file creation.
  7. Contact Support: If none of the above solutions work, consider reaching out to Autodesk support for assistance.
Remember to save your work before attempting these troubleshooting steps. If you need further guidance, please provide more details about the error messages or issues you’re encountering.
AutoCAD Inside the Factory
