Hello All
I have supplier details in DWF format.
I can look at the file in the Autodesk online Web Viewer, but when I try to DWFATACH attach it into my AutoCAD drawing I get an error message.
This doesn't make sense to me, if the web viewer can display the file any Autodesk software should be able to deal with the file.
Any ideas how I get the file to show in AutoCAD
My goal is to get the detail into AutoCAD to be able to use it in our drawings.
If there is a better way than DWFATACH, I would be grateful to know.
Attached the dwf file in question
Thanks Tobi
P.S. different questions are
-why the supplier only provides DWF and
-why AutoCAD doesn't seem to be able to just import/open DWF files
Thanks a lot.
That explains why it doesn't work.
Quite disappointing that a software that expensive can't do 3D-dwf.
But then Autodesk prefer using their developers to introduce pointless features like counting how often I have used which command.
But hey it is what it is.
Any suggestions how I can convert the file somehow somewhere to be able to import it.
Edit: Just spotted that the link suggest using Design Review to convert - will try
If it fails:
I will try to get a different formant from the supplier, but don't know if they will comply.
Regards
Tobi
