PDF to DWF
PDF to DWF
PDF to DWF
I request if someone could help m in knowing how much time it require to convert PDF to DWG....
Thanks in advance...
rkmcswain
Probably depends on the tool used to do it, and the amount of content in the PDF file. A few seconds to a few minutes would be my guess.
Thank you for the help..
cadfmconsultants
RK, agreed, it would depend on what tool is being used and the amount of content in the original PDF, but also be aware of the PDF quality. Make sure the originator of the PDF's being used has set their PDF output settings to the highest res they can use. This helps pick up geometry, text and dims quicker and might speed up the process a little. SCB.
Shaun 'CADjedi' Bryant
AutoCAD and Revit ACI and occasional Tinkercad user
Not Just CAD! - The Official Blog of CADFMconsultants
Twitter | LinkedIn
