- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am drawing an object in AutoCAD 2016 and must include text for instruction. However, after typing in my text, it shrinks down to microprint. How do I get it to normal size?
I first encountered this problem with dimension lines, but to solve the problem, I simply had to go to manage dimension styles, then modify, and adjust the scale to 25.4.
Again, I encountered this problem with leaders but solved the problem by doing the same as above (but for leaders), adjusting the scale to 15 to achieve a close-to-equal size (the scale of leaders vs dimension lines is not the same).
So, now that I have encountered this problem with text, I assumed I would have to simply adjust the scale through the same meathod as above, but I cannot find and option to adjust the scale.
I am working in milimeters. I am sure the answer is simple, but please be patient
