Community Challenges
Dessinez une bouteille de Klein
Revit Bottle
I can attest this will be the most clunky entry in the challenge, but still I wanted to prove Revit is capable of out of the box complex curved geometry. Remember this is not a NURBS modeler.
Create: Revit: Family
         --> Generic Model.rfa
Create: Revolve
         --> Draw center axis
         --> Use arc-lines to create outside shell shape of lower half (non-neck)
         --> Use offset tool to create inside shell shape of lower half (non-neck)
Create: Sweep
         --> Draw neck shape
         --> Edit profile, draw circle that matches all the shapes used in the revolve
Apply: Material: Glass
         --> Select the upper and lower modeled parts and apply material
(edit curves/model to desired look/fit)
Render Image
1 Comment
Comments
I did'nt expect this to be done in Revit ! That's great !
