This is probably going to be a silly question. I have two files appearing in my data panel that are copies of files I already have in Fusion except they have the Fusion icon showing just like they do when you export a file from Fusion. When I try to open either one it doesn't open in Fusion but instead opens in a new tab in my browser within what appears to be the Fusion environment. I've attached a screen print of my Data panel as well as a screen print of the browser screen when I open the Fusion file.
Thanks.
Solved by GrAndAG. Go to Solution.
When you do "Export" you can mark the option "Save to a project in the cloud". In this case the .f3d file will also be stored in the cloud along with file on the disk. That's why you see that file in the data panel.
