Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Trouble installing Fusion 360 on a Mac from Autodesk.com? Workaround available.
3 REPLIES 3
brianrepp
2971 Views, 3 Replies
For those running Mac OS X 10.11.4, there is a known issue if you're trying to install Fusion 360 from Autodesk.com (as opposed to Mac App Store).  Apple is aware of the issue, and working towards a resolution.
Currently, if you are trying to install by double-clicking on the installer downloaded from Autodesk.com, you will get the following error message:
To workaround the issue, right click on the mounted "Double Click To Install.app" item and then select Open from the context menu, followed by Open in the warning message:
3 REPLIES 3
carlsonZMF2Z
in reply to: brianrepp
I think installing from a developer's website attempts to bypass your Mac's security (I think you can do this but then you need to go the the System Preferences and turn-off the the security). To maintain the security 'sandbox' install directly from the Apple App Store ... the Apple App Store worked for me without turning off security.
It's a problem with the signage of the 'downloader', if an app from a developer's site is correctly signed it will allow you to install.
This needs to be said, App Store versions take longer to be updated because of the submission process. Not using the App Store version will ensure you have the latest version when it's released.
I always advise my students to use the Apple App store if they use Macs … it up to the software vendor to keep their software up to date on the different systems they offer. (If they use Windows I tell them to go to the AutoDesk site.)
During the course, I am using Xcode (with Swift) to demonstrate solutions to simpler problems … then Octave for some matrix manipulation. I wanted to show them from where things ‘evolved’ (I would go all the way back to Fortran but I’ve come to appreciate Swift). You know the students all have these college math sequences but there is a disconnect between the math they’ve been taught and what they can do with it.
Then finally, I use Fusion to demonstrate to students how the modern numerical software can be employed to analyze complex parts. Most of our time in the second half is covering FEA theory, performing example problems, dealing with boundary conditions, and understanding how exact and the FEA solutions differ.
Really, my course is an undergraduate introduction to finite element methods, matrix techniques, as well as some finite differences. A mishmash of numerical work!
I was surprised that 46 students signed up! I must be easy.
