Sweep with guide rail question
TrippyLighting
Consultant Consultant
Message 1 of 12
TrippyLighting
While trying to help a user in this thread with modeling a drill bit.
the coil tool makes this seemingly simple task quite a chore and I am not entirely sure the sweep tool does what it should.
The question if I start with the sweep profile a the broom of the drill bit perpendicular to the Z-Axis, and provided that I am using a guide rail, should the sweep action not also end parallel to the original sweep profile so also  perpendicular to the Z-Axis ?
Replies (11)
Message 2 of 12
PhilProcarioJr
@TrippyLighting
"The question if I start with the sweep profile a the broom of the drill bit perpendicular to the Z-Axis, and provided that I am using a guide rail, should the sweep action not also end parallel to the original sweep profile so also  perpendicular to the Z-Axis ?"
It should but the current implementation doesn't and it drives me nuts. If it did it would solve hundreds of problems.......
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 12
TrippyLighting
@PhilProcarioJr wrote:
...the current implementation doesn't and it drives me nuts....
You have got to be kidding...
That deserves a face palm from the master of face palms Dave Jones from the eevblog:
via GIPHY
Message 4 of 12
PhilProcarioJr
@TrippyLighting
.....and people wonder why I keep complaining that the core tools need to be the focus.....
Phil Procario Jr.
Message 5 of 12
colin.smith
Hi @TrippyLighting
Unfortunately @PhilProcarioJr is right (again).  We have been reviewing several of the modeling tools for improvements. I will add this to the list.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Alias Create VR (aka Project Sugarhill)
Automotive & Conceptual Design Group
Message 6 of 12
PhilProcarioJr
@colin.smith
"Unfortunately @PhilProcarioJr is right (again)."
I could be wrong more often if it would help. Smiley Very Happy
Phil Procario Jr.
Message 7 of 12
colin.smith
@PhilProcarioJr, I doubt you could. I just like it more when you are right about positive things Smiley Wink
Colin Smith
Sr. Product Manager
SketchBook
Message 8 of 12
colin.smith
@PhilProcarioJr I doubt you could.  I just like it more when you are right about positive things. Smiley Wink
Colin Smith
Sr. Product Manager
SketchBook
Message 9 of 12
TMC.Engineering
I do like his blog 👍
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
Message 10 of 12
JonSchaeffer
LOL Exactly!!!!
Face palm.
This has been a goal of mine for a few years now, I keep coming back to it with zero results...
Looking forward to the day it becomes a reality...
www.genesisprecisionaz.com
info@genesisprecisionaz.com
Message 11 of 12
TrippyLighting
Yes, this is another core tool that does not work as it should and in effect making  this really a chore.
The only thing I have not tried is a loft with rails to get this done. You have to draw the line somewhere 😉
Message 12 of 12
TheCADWhisperer
A few years back - modeling guru Jeff Howard did an iPart factory of twist drills.
In the spring of 2006 I used his process to write a tutorial for creating the geometry (non-parametric) in AutoCAD.
Back then my hair hadn't turned gray yet, Apple hadn't announced the iPhone, and my car didn't have GPS...
