Spline Tangency
Spline Tangency
neljoshua
Advisor Advisor
Spline Tangency
neljoshua
Does the tangency constraint no longer function with 3D splines?  I cannot get it to select one.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
FrankCao
Hi Josh.nelson,
Thanks for reporting this issue. I think we have a bug here. I have reported this issue to our development team to take a look.
Now in the meantime, when you are adding tangent constraint, could you try select the edge/2d line first, then select the 3d spline. That might help in some cases.
Frank
neljoshua
@FrankCao,
Thanks for the info and the response.
I did try selecting the line segment (rather than the spline) first, but I was unable to select either.
__
neljoshua
In case anyone is wondering, this bug is now fixed.  Thanks @FrankCao & the rest of the Fusion team!
__
