Highlighted
30 Kudos
Rotate cube to stand on one corner?
93 Views, 4 Replies
Friday
Ok, this is embarrasing, but I have a really simple question:
Assume I have a solid cube that was extruded from a sketch on the top plane, and one corner/vertex is at the origin. If I want to rotate this cube so that it stands on the "origin" corner so that the opposite (diagonally) corner is perfectly vertical above it, is there an easy way to do that?
I know I can rotate it twice, first by 45 degrees on x and then by 35.264 degrees (or to be precise: atan(1/sqrt(2))) on y (attached file), but is there some non-numerical way, like creating some construction geometry and snapping or aligning to that?
Here's another way using a sketch.
Mark
AUTODESK EXPERT ELITE
2189 Kudos
860 Solutions
Re: Rotate cube to stand on one corner?
Friday in reply to: mroek
Here's one way using a joint. I had to make the cube a component, this might be a good idea as the sketch moves with the body.
Mark
Mark Hughes
Owner, Hughes Tooling
30 Kudos
Friday in reply to: HughesTooling
@HughesTooling
Thanks, I didn't think of that. However, I would prefer to just be able to rotate the body without converting it to a component first, but you did provide a solution.  :-)
I'll hold off a bit before accepting it, in case someone else chimes in with different ideas.
2189 Kudos
860 Solutions
Mark
Mark Hughes
30 Kudos
@HughesTooling
Thanks a bunch, I actually like that method better, and will accept that as the solution!
