Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Rotate cube to stand on one corner?
4 REPLIES 4
mroek
3293 Views, 4 Replies
Ok, this is embarrasing, but I have a really simple question:
Assume I have a solid cube that was extruded from a sketch on the top plane, and one corner/vertex is at the origin. If I want to rotate this cube so that it stands on the "origin" corner so that the opposite (diagonally) corner is perfectly vertical above it, is there an easy way to do that?
I know I can rotate it twice, first by 45 degrees on x and then by 35.264 degrees (or to be precise: atan(1/sqrt(2))) on y (attached file), but is there some non-numerical way, like creating some construction geometry and snapping or aligning to that?
4 REPLIES 4
HughesTooling
in reply to: mroek
Here's one way using a joint. I had to make the cube a component, this might be a good idea as the sketch moves with the body.
Mark
Mark Hughes
Owner, Hughes Tooling
mroek
in reply to: HughesTooling
@HughesTooling
Thanks, I didn't think of that. However, I would prefer to just be able to rotate the body without converting it to a component first, but you did provide a solution.  🙂
I'll hold off a bit before accepting it, in case someone else chimes in with different ideas.
HughesTooling
in reply to: mroek
Here's another way using a sketch.
Mark
Mark Hughes
mroek
@HughesTooling
Thanks a bunch, I actually like that method better, and will accept that as the solution!
