Hello folks,
First thing first: let me tell you that I'm just starting to work with fusion 360 and any kind of 3d modelling software so please be patient with me. I highly apprichiate any help!
So my question:
Can somebody explain me step by step, that how can I fit the wheel inside the T - slot? (picture is enclosed)
I would like to demonstrate the motion of the wheel in the slot.
but when I trying to use align tool it always align the center point of the wheel instead of the surface..
Thank you for your help!
Solved by daniel_lyall. Go to Solution.
It's not easy to align the wheel with the extrusion because you need the fillet arc on the wheel to be tangent to the fillet arc on the extrusion.
The wheel and the extrusion are a poor match. The load bearing surfaces will be extremely small and the wear on either the extrusion or wheel will be high. It will be very difficult to maintain accurate alignment.
ETFrench
I checked your file and I think the best way to get this done is by using a joint, and for that you need to create a joint origin between the 2-interior faces of the T-slot ( shown in the picture below ), and then use the joint command to align your wheel perfectly in the middle, but your wheel is too big ( shown in the picture below ) so I recommend you make it smaller to make it more sense.
Hope that helps, regards.
Saeed
Thank you for your advice!
I cannot make smaller wheel it need to be run on the sides of the slot.
I mean as it could fit in the slot. (as you can see on the enclosed pics - created by etfrench)
Can I make two joint origins side by side of the slot and align the wheel to them?
Use a joint origin on the extrusion, under type use between two faces, then just snap it into where ever (try to get it level with the top of the extrusion), then you can move it to where you wont it to be, you can edit its position after it been placed.
then just use a joint between the dead center of the wheel and the joint origin. I will pop up a screencast soon.
@SaeedHamza yes it's your idea.
All rights reserved lol 😛
But nice screencast bro
Using a joint origin at the top of the extrusion will not work as demonstrated in the screenshot I attached. Unfortunately, Fusion 360 doesn't have a tool to mate tangent arcs, so the OP will need to use a sketch and other geometry to determine the precise position the wheel will ride on the extrusion.
Mating these wheels and extrusions is really not a very good idea if this is for a CNC application.
ETFrench
If he sits the wheel centered at the end of the extrusion and zooms right in you can get it lined up quite well
I'm planning to make my low budget laser engraver/flatbed plotter machine based on popular diy cnc kits just like shapeoko 2 or OX cnc. For sure with these thinny extrusions I only want to cut balsa wood and cardboards.
I tried to choose my building parts Based on my middle european location and low budget. But honestly I would like to know your opinion.
Why do you think that these materials are not good for application?
Both the wheels and that extrusion will work well for that application, just not together. The bearing surface between the two is very small which means the load will be high, which in turn means the wear will be high. Either use a wheel designed for the extrusion or an extrusion designed for the wheel.
ETFrench
