so I am tying to setup parameters for a sweep so I can easily change them but the percent distance around the sweep is giving me problems
any know what type that value would need to be ?
I have tried the distance, angle and percent types work so far
any help would be great
Solved by jeff_strater. Go to Solution.
The sweep value, I believe, is "unitless" type, just a range between 0 and 1.0.
Jeff
yep that did it, I didn't even notice the unitless type up at the top of the list
Thank You
C
