Probably a simple solution, but I can not find a way to reset the position of a objects to the baseline of the design area.
In 123D Design is is possible to achieve this by selecting a object and the pressing the "D" on keyboard.
So how is the same functionality working in Fusion 360 ?
Best regards
Lars Lindgren
Solved by jeevesme. Go to Solution.
There is no feature like that in F360. You can use the Move tool and use point to point:
