Is there a way to get position of an object ( Bounds (overall size) and position on grid without going thru alot of clicks??)
Also is the a way to put WCS on screen permanently
Is it possible to clarify this statment some? It sounds like you are asking for
Is that correct?
Curerntly, I'm not sure how to obtain a bounding box size or coordinates (other than to manually draw a box). However, there may be some functions in the API that might be able to provide this information. I can ask around and see what I find out.
The closest thing to a global coordinate system indicator is the default Work planes/axis/origin. If you enable the top level work features the color of the axis correspond with the axis.
Think the colors of the rainbow, Roy G Biv:
Red = X axis
Green = Y axis
Blue = Z axis
I note there is a global coordinate system indicator located in the Simulation Environment. On trick may be to switch to that environment temporarily to get your orientation down.
I went looking through the Fusion 360 Ideastation for a similar request (website below). However, I was unable to find a enhancement request that matched. You may consider suggesting an idea in the Fusion 360 Ideastation, below.
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/idb-p/125/tab/most-recent/page/103
I hope this helps. I will circle back when I have more information about the bounding box.
Thank You,
I found an API object acll BrepBody.boundingBox Property I think that could be used to obtain this information.
http://help.autodesk.com/cloudhelp/ENU/Fusion-360-API/files/BRepBody_boundingBox.htm
http://help.autodesk.com/view/NINVFUS/ENU/?guid=GUID-9ce5053e-72b6-4a47-8172-e4223fb4caff
I'll keep digging to see if I can find an example.
I see that there has been some discussion in this post.
