Hey there!
My current project involves an assembly of an customer, who wants testing fixture to be made. I got the data as NX-files, imported them respectively uploaded them into my project, and clicked "Insert into current design". To keep the assembly's integrity i formed a rigid group.
Now, when I create a sketch, project lines from the assembly into it, draw circles... basically whatever action I take within the sketch, Fusion needs quite a time, up to 20 seconds, to finish the command and get responsive again.
The memory usage of Fusion is about 2500MB but i also saw almost 4500MB when sketching. This was the reason why I upgraded from 8GB of RAM to 16GB but I see no performance gain.
Unfortunately I am not allowed to share the design (NDA).
component.count of assembly:
Component.Counts
With Overrides: LeafOccurrences 17: Bodies 3906: VisibleLeafOccurrences 12: VisibleBodies 3898: LeafOccurrencesWithVisualMaterialOverrides 0: OccurrencesWithTransformOverides 19
graphics diagnostics:
[GPU Information]
GPU Device: NVIDIA Quadro M1000M
GPU RAM: 2048 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: W\S.ystem32\DriverStore\FileRepository\nvltwi.inf_amd64_d94886d3361927cc\nvd3dumx,C:\WINDOWS\System32\DriverStore\FileR:21.21.13.7684
GPU Driver Date: Unknown
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Display
[Limit effects to optimize performance]
Off
Thanks in advance!
Greetings, Norbert
Are you selecting a face when you create a sketch? If you are all the edges of that face are auto projected in so you could end up with hundreds of curves in the sketch before you start. There are 2 workarounds, create a plane on the face then select for your sketch or turn autoproject off in preferences. You might want to turn off Auto project on reference as well. With auto project off you will need to project in anything you need as a reference but it does keep your sketches a lot cleaner.
Mark Hughes
Owner, Hughes Tooling
The autoproject option is off, this "feature" annoyed me very early 😉
But thank you for the reply!
And by the way...
what is the reason for the poor "sketch-performance" when having many lines, construction lines, constraints, or patterns in one sketch? Because it is very often the case that you define the geometrical relationship of a construction within the sketch. Which often requires a lot of geometrical construction.
I think it comes down to the sketcher is constantly looking for and trying to add constraints as you draw. @innovatenate can you help?
Thanks Mark
Mark Hughes
For the sketch you showed in the Screencast, it looks like there is a lot of model symmetry that you may be able to take advantage of. Instead of projecting everything into the sketch, might it be possible to simplify the sketch and then mirror whatever features or geometry you need to create in 3D?
Contributing factors for the performance of Sketches are the options at the top of the sketch palette:
Disabling 3D, snap, grid, profile, constraint and point display will help since all of these little features requires some computation.
Another thing I'm wondering about is does the sketch need to maintain the associativity to the source geometry? If not, then you could right click on the sketch figures, select break link to break the associativity. Creating associativity between 3D geometry and sketch entities is another thing that might lead to the sketch performance.
In the design that was imported, how many bodies do you have per component in the design? I'm wondering if the issue is that you have like 1000 bodies in a single component somewhere in the browser.
It might be worth a test to use activate a component to see if it can help to filter down some of the design. If you activate a component (maybe one with only a single body in it) and then try to project a sketch, is it any faster?
Another helpful trick is to select all the sketch geometry and select Fix. This should help to "lock down" and reduce the computational overhead of creating new sketch constraints.
I hope that helps!
Hi Norbert,
yes it's painful to watch Fusion taking so much time when this really should not be the case.
Would you be willing to (or able to) share you design with us so we can have our sketch development team take a look at and figure out what is slowing you down?
you can private message me here or email me at jamie.gilchrist@autodesk.com.
Hey Nathan!
First of all thank you for the reply and the input you gave.
-> The sketch is by far not complex, see the screenshot of a construction with a much more complex sketch were I'm experiencing no performance problems. I still do not understand what's the problem with complex sketches - it is a line drawing and with current computational power (talking of over 2,5GHz and 16GB RAM) it shouldn't be a performance restricting factor!
-> No improvement at all!
-> Yes, i need the association to the source geometry. And I do not like the idea that i have to draw my sketch all over again when i change something in the source geometry.
->The imported design is a plastic case enclosing two sandwiched PCBs. The PCBs components exported from Altium Designer and they together contain about 3900 bodies. There are also 650 Unstiched geometries in one component. I tried to delete them (selected like in the screenshot), suspecting them being the cause for the bad performance, but it was not possible without loosing all other bodies too.
-> Here is a screenshot of the construction tree. Can you please give an example. "B150_SIP_Modul" is the imported design, it was an NX assembly. Every component has only few bodies, max. 3, except "SMV01-V21" and "SMP01.V21", which are the PCBs (~3900 bodies + 650 unstiched)
@JamieGilchrist: Thanks for the reply. Unfortunately I'm not allowed to share the design, as it contains customer data which we signed a NDA with.
Thank you for your help!!!
With all those unstitched bodies have you tried switching to the patch workspace and trying to stitch them. If they should form more than one body stitching could be tricky though.
Mark
Mark Hughes
Thank you for the detailed response.
The below screencast clarifies what I'm trying to suggest with activating a component. I'm not 100% that it will help, but I thought it might be worth a try.
Hey Nathan,
thanks for the explanation! As my work progressed, yesterday I did just that what you've described in your screencast - converted one body into a component, acitvated it and drew a sketch. But I could not see any improvement.
Next thing I will try is to export into a SAT-file...
I was able to stich those unstiched bodies together - there are two connectors which were missing a patch to be fully closed. Now the 654 unstiched objects merged into two normal bodies. But i still see this:
You suggested to use the validate command under inspect in the patch workspace... unfortunately there is no such command.
