Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Multiple Joint Between Same Component
4 REPLIES 4
McBride22
415 Views, 4 Replies
I have a project of an aircraft Control Wheel, a Piper Archer.
However I can seem to get the Joint to work properly.
I want the Control Shaft Component to slide through the Panel mount Component as well as rotate inside of it
But I cant seem to have both, only one at a time
http://a360.co/2pqjX5n
4 REPLIES 4
jagboy2013
in reply to: McBride22
Use a cylindrical joint.  It allows both rotation and translation.
Ray L.
davebYYPCU
Your file in A360 doesn't show me the joints, will download it bit later,
quick question, when you made the joint to the shaft - bearing, was it Cylindrical, if not, that's the right one,
If it is cylindrical the preview animation was correct, then you need to set the move limits for slide and revolve, there is a limits dialogue box, but it only shows one option at a time, you have to select at the top, both directions, otherwise you will get what I think you are seeing.
Might help,
McBride22
in reply to: davebYYPCU
Thank you for your time.
I now cant seem to get the sleeve Bearing to work. I need the Outer Component move with the rest but not to rotate
rigid but not rotate with the rest
davebYYPCU
Light bulbs are your friend,
Rigid joint the outer shaft to the face plate, I turned off the shaft to see the bearing plate centre icon.
Use Cntl / Cmd keys when you get close during selections for the joint origins.
Might help,
