Motion of linked components
4 REPLIES 4
mnicol12
582 Views, 4 Replies
I am struggling with joints and motion. The issue I am having is the following:
I have a component including more subcomponents (linked) that is made as a subassembly. If I insert this subassembly into another main assembly and try to make a joint, only the body without a link will move. The two linked components in my subassembly are static. I can't figure out why...
Here is a link to the subassembly: http://a360.co/2ldKYqR
Is my workflow totally screwed up and the cause of this?
Maybe I should just drop the subcomponents and subassembly thing?
Best regards, Mogens
4 REPLIES 4
josef.kucera
in reply to: mnicol12
Hi @mnicol12
is this what you want?
Josef
Josef Kucera
Fusion QA
mnicol12
in reply to: josef.kucera
Exactly that, yes! So make it a rigid group is the way..
Thanks a lot!
Do you have any comments on the workflow I described? Is this a weird way of doing it?
Best regards,
Mogens
josef.kucera
I noticed that you have in the design some bodies which you then assembling together with components. I would prefer to work with components in regards with assemblies since components represent real-world parts and serves as containers for bodies/sketches and other entities whereas bodies serves as modeling entities used to add or remove geometry to achieve the final shape of your design.
So I would prefer to stick with R.U.L.E. #1
Josef
Josef Kucera
Fusion QA
mnicol12
I will try to improve on the workflow according to what is described in the link you gave.
Thank you!
