Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for Fusion 360?
Solved by matthew.d. Go to Solution.
December 2017
November 2017
October 2017
September 2017
August 2017
July 2017
June 2017
May 2017
April 2017
March 2017
Body groups are unselectable in the CAM browser of Fusion 360
Changing the opacity of a body does not work in Fusion 360
Sketched arcs reverse direction when connected by a line in Fusion 360
The Myriad CAD font cannot be exploded or extruded in Fusion 360
Designs with non-standard English characters in their name will not generate a Setup Sheet in Fusion...
Trying to open Fusion 360 in another Space on a Mac causes elements of the user interface to not app...
Using a right angle head attachment with Fusion 360’s CAM capabilities
Clearing out residual files from a failed installation and reinstalling Fusion 360
Fusion 360 crashes upon startup with a new installation (Duet Display or Kairos Driver issue)
3D printed objects do not match model dimensions from Fusion 360
Animation fade out behavior is abrupt with certain appearances in Fusion 360
How to avoid bored geometry in a Turning > Face Profile operation in Fusion 360/ HSM CAM
How to save Fusion 360 designs for use with M3D Printers
How to use Manual NC options to manually add code with Fusion 360/HSM CAM
Truncating the design timeline when a component is activated in Fusion 360
Adaptive clearing strategies appear to be ignoring Rest Machining settings in Fusion 360’s CAM works...
Fusion 360 - Delay when switching between designs and changing to the CAM work space
Switching between sheets in a Fusion 360 drawing causes the design to be flagged as if changes have ...
Error: “Database table is locked” when installing or updating Fusion 360
Converting Fusion Team trial to subscribed state
Fusion 360 installation troubleshooting
Fusion 360 Lab installation works under Administrator account and fails to open with a student accou...
Changing the default external g-code editor in Fusion 360
How to add a Post Processor to your Personal Posts in Fusion 360
How to edit contours in Fusion 360 CAM
Lead-in angles for a Turning Profile are not generated correctly with roughing passes enabled in Fus...
Project avatars are gone after Fusion 360 updates
Sketch contours copied from the XZ plane are inverted when pasted into a new sketch in Fusion 360
Unexpected results with Hole feature extents set to “Through All” in Fusion 360
Viewing Fusion 360 designs in VR
Working with lead-in/out moves in a Turning Profile operation in Fusion 360
How to share a link to a design with project collaborators in Fusion 360
Fusion 360 crashes when left idle for an extended period of time
How to setup 2D adaptive clearing strategies to do finishing passes in the Z direction in Fusion 360...
How to remove a Linked Component / XRef from the timeline
How to add a custom 3D printer to the 3D Print Utility in Fusion 360
Fusion 360 - Sign in Failure Due to Service Outage
February 2017
How to enter the Fusion 360 Monthly Challenge
How to generate G code from a sketch in Fusion 360
How to toggle draft and zebra analysis on and off
How to convert a 3d scan *.stl mesh into a solid body within Fusion 360
WinError 740 – The Requested Operation Requires Elevation
CAM templates are not saved to the CAMTemplates folder from Fusion 360
CAM toolpaths are invalidated when component visibility is changed in Fusion 360
Creating first and third angle projected views in Fusion 360
Finishing passes do not follow confinement offsets in Fusion 360
Limiting permissions on shared tool libraries in Fusion 360
Managing CAM templates in Fusion 360
Mirrored sketch entities are not previewed correctly in Fusion 360
Selecting decimal inches as a measurement unit in the Android Fusion 360 app gives results in decima...
The Order by Tool function does not work when both patterns and WCS duplicates exist in Fusion 360
UI elements from Fusion 360 float on top of other applications
Data limits for Fusion 360
F0 feed rates after chamfering plunge moves in Fusion 360
Fusion 360 crashes due to installation of outdated add-ins, DXF for Laser or Helical Gear Generator
How to animate joints in Fusion 360
How to install a cloud tool library in Fusion 360
Paste vs. Paste New in Fusion 360
Screencasts do not include Fusion 360 ribbon, browser, and intended audio
Fusion 360 crashes upon waking from sleep in Mac OS: Outdated Version of Autodesk Screencast
How to import a *.cps file from the Autodesk CAM Post Library into Fusion 360
How to move/copy a sketch, face, body or component in Fusion 360
How to Use Fusion 360’s Interference Detection to Avoid Cutting Into Your Fixtures
An interference is reported by the Simulation Pre-check in Fusion 360
How to remove the “in use by” flag from copied Fusion 360 design in Data Panel thumbnail information
Toolpath for text does not generate properly if the component was moved in Fusion 360 CAM
Unable to restart Fusion 360 after closing the initial launch after installation
How to locate, uninstall, and add an Add-In from the Autodesk App Store in Fusion 360
No point available to use as reference to scale a sphere in Fusion 360
Fusion - This process failed because of another installer live update in process.
Drawing viewed in Autodesk 360 appears differently than when viewed in Fusion 360
How to insert a standard part into a Fusion 360 design
How to set custom navigation commands in Fusion 360
How to scale a mesh according to the world coordinate system in Fusion 360
Menu missing from the main ribbon in Fusion 360
The body in Fusion 360 is orange and has no volume or mass associated with it
Fusion 360 is unable to make a closed mesh
Sketch geometry offset from a projected curve does not update correctly in Fusion 360
The animation timeline in Fusion 360 disappears after an animation is reversed
The CAM simulation dialogue does not remember previously used settings in Fusion 360
The show/hide lightbulb moves in the Fusion 360 browser tree
You would like to program a manual stop or tool change in Fusion 360
Your post processor will not post the new stock transfer operations in Fusion 360
Defining the direction of a rotary axis in Fusion 360
Editing CAM setup sheets created with Fusion 360
Focus is lost when extruding a negative decimal distance in Fusion 360
How to export components from an assembly file as individual files from Fusion 360
Mesh bodies are not recognized in the CAM workspace of Fusion 360
Moved/ translated components jump after command in the Animation workspace of Fusion 360
PNG decals are scaled incorrectly when inserted into Fusion 360
Unable to select which CAM operation to use in Fusion 360
How to get Graphics Diagnostic information in Fusion 360
January 2017
How to do an automatic Clean Uninstall for Autodesk Fusion 360
How to edit a feature that appears in the browser tree within Fusion 360
How to install a cloud post in Fusion 360
Importing into Fusion: stitching and validating solids
Missing upload file icon in the Fusion 360 data panel
Problem install Fusion360 on macOS
What specific DXF filetype is output by Fusion 360?
You would like to add spring passes to a turning operation in Fusion 360
