Is there a way to import a graphic file like jpeg or png into a drawing file?
Thank you
Cam
Not within F360. I use Adobe Acrobat Pro to insert any images I want into the .pdf that F360 spits out.
I better ask just in case you're using the wrong terminology, do you want to insert a jpeg into a 2d drawing in the drawing workspace or do you want to insert a canvas in the model workspace?
There is an option to insert a image into a 2d drawing title block but you can pick any snap point on the sheet and scale to size.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-B4BC813B-8697-4632-B57E-AC1E582E8C7A
If you want an image in the model workspace there's an option insert canvas on the insert menu.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-FBA87F37-2A42-47D2-B1C1-BED8423A7E55
Mark
Mark Hughes
Owner, Hughes Tooling
Hey @camstuff - this is on our roadmap for Drawings, so stay tuned! You can always check on the current status of what the Drawings team is working on by visiting our roadmap mural, too!
Best,
Timera
