Attached, I slapped together some shapes and am calling them my final part.
My goal would be to produce the mirror part as a negative, example for parts holding or mold making. Can you tell me how to do this.
I have tried offset planes and midplanes. Each time, when i extrude the plane, it absorbs the original part as a part.
This is for CNC Milling, if that matters.
Thank you.
The combine tool set to cut should do what you're after. Also have a look through this thread on Rule #1, using components will make it a lot easier. Screencast below and the file's attached.
Mark
Edit forgot the link to the Rule #1 thread.
Mark Hughes
Owner, Hughes Tooling
