I have a simple body (box) that I need to divide into 4 pieces (side by side not quadrants)
I have looked up Split Face and Split Body but the links just seem to show where to find the tools, but following those steps doesn't do anything (the steps end before anything splits)
I select a Split Body and select a Face
That gives me a plane, but then what?
(Apologies if this is a dupe - first post seems to have disappeared somewhere)
Solved by HughesTooling. Go to Solution.
An easy way to do this it create a sketch with 3 lines, use split body and select the body then a line then OK. After the split the sketch will turn off so you'll need to click the light bulb next to the sketch to turn it back on, then repeat the split body 2 more times.
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks for the info Mark!
I need to split evenly.
Isn't there a way to specify how many sections I want and have it do the math?
Here's a quicker way using a zig zag line.
Mark
Mark Hughes
You can add dimensions to the sketch and reference the rectangle.
In this image d1 in parameters is the length of the rectangle\Box, then in the dimension I've highlighted i entered d1/4. When you add dimensions to the other 2 lengths click on the dimension you've entered d1/4 and it will use that dimensions value. I've attached the file, to open, from the File Menu select New Design From File.
Mark
Mark Hughes
Just noticed I should have referenced parameter d2 not d1. I've attached the corrected file. If you right click the Box in the time line and edit it's size it should update and keep all 4 parts the same size.
Mark.
Mark Hughes
Mark thanks for this great info!
There has to be a simple way to divide though.
What if I want to divide into 100 segments. I would have to sketch that many zig zags?
The trouble is how usfull a command is it, I've never needed anything like that and I don't think any program I've used has an automated way of doing it either.
Why do you need to divide that many times, if you need 100 idetical parts make 1 and use Rectangular Pattern to make 100 copies.
Mark.
Mark Hughes
Here's an idea, make one cut with split body then use Rectangular Pattern to make the rest. For pattern type select Feature, then select the Split from the time line. I've attached a sample file.
Mark
Mark Hughes
