Is there a way to adjust lighting effects for all components in the canvas scene?
I'm not asking about setting up a render, but how to brighten things up while working on a design.
Solved by michallach81. Go to Solution.
You can replace exr image for light map... on my laptop this is a line to file with environments:
\Users\Michał\AppData\Local\Autodesk\webdeploy\production\d9669130722421630c2abe0de156a31ef7089d9c\Neutron\Server\Scene\Resources\Environments, yours should similar.
The new map will be available only on that specific installation.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
I tried for awhile and I might be able to get to a similar directory location if stuck with it, but if I did I'm not clear what to do when I get there.
Not urgent, though.
So to be clear, there is not currently a global lighting effects adjustment, and I could request it as a feature enhancement?
Thanks, Michal.
