Hi Matt,
I'll speak with our hardware experts about what might be the best choice.
Incidentally, what happens when you try to run Fusion 360? Are you able to complete installation? If so, what happens after that?
Thanks!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
Hi Matt,
Sure thing; at that age it may well be a bit underpowered. Assume you may have tried these, but just in case:
Also, if you click the Copy to Clipboard button from the Graphic Diagnostic dialog, and copy/attach it here (or send it to jake.fowler (at) autodesk.com), we can probably confirm whether or not Fusion is likely to run.
Will get back to you soon on machine recommendations.
Jake
Jake Fowler
Fusion 360
Here's the copy of the Graphics Diagnostic like asked:
[GPU Information]
GPU Device: Mobile Intel(R) 4 Series Express Chipset Family
GPU RAM: 64 MB (Integrated card)
GPU Driver API: DirectX 9.0
GPU Driver Version: 8.15.10.1892
GPU Driver Date: 09/02/2009
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Notes]
1. If you have another discrete GPU on your system it is recommended to run Fusion on it to get better performance.
2. The graphics card driver version is old and could be out of date; please check with your GPU vendors to download and install the latest one.
3. The effects could slow down the graphics rendering; try to limit them for optimum performance.
[Limit all effects to provide optimum performance]
On
This is graphics card driver issue. It is too old and is more than 6 years ago. We have other customers reporting the same problem and they can fix it by installing the newer driver on their machines.
Can you please try to install the new driver from this link:
You probably need to uninstall the old driver first before installing the new dirver if you run into any problem when installing the new driver above.
Chengyun
Fusion Development Team
It seems that the link above I provided is for 32 bit OS. You will need to install 64 bit driver.
Please use this link instead:
https://downloadcenter.intel.com/search?keyword=Series+Express+Chipset+Family
Hi just tried both 64bit drivers download on this page and both says that "these drivers are not validated for this computer and use the driver from the computer manufacturer". But when i tried using the Gateway website app or Intell app both say that my drivers are up to date. I don't know what to do at this point. I'm really in the need of new laptop that's why ask if any of the 3 i mention in the first message were any good.
Thanks that's really what i wanted to hear, i certainly don't have enough budget for a more expensive laptop. I also don't mind i f its a bit slower, i'm not a business, i just wanna use Fusion to learn and play with cad/cam technologies.
Thanks again
Hi Matt,
Besides graphics, I'd also recommend going for the machine with the fastest CPU clock speed you can (which I think is the HP from the examples you posted). This should give you the best performance in modeling & general Fusion 360 workflows.
Jake
Jake Fowler
Fusion 360
