I've exported a drawing to DWG format, then import it to illustrator(CS5) but failed while shown"unknown format". Then I asked a friend to open that DWG file with AutoCAD, it just like several images for each view but not vector contours or lines, so what's the problem?
My guess would be that you are having an issue with the model documentation views in AutoCad. I believe you will need to open in AutoCad, then use the exportlayout command to get a dwg file with the vectors that you are expecting.
Hi Ben,
Thank you for your reply, I've tried as your suggestion and the new DWG file works fine, but still cannot be import to Illustrator, I guess there is a problem with the DWG format which was export from Fusion 360 Drawing, do you have any idea on this?
Much Appreciate
ShaoFeng
Sorry I don't. I don't have Illustrator and don't know it's requirements. Hopefully someone else will have the answer.
