Fusion360 doesnt start properly
KirillChepizhko
Message 1 of 27
KirillChepizhko
What is happening ?
When I close all those and get to the main UI my dashboard is gone.
Replies (26)
Message 2 of 27
masa.minohara
Please try "clear user cache data" in Help and "Restore Defaults" in Preferences, and let me know if these fix the issue.
Also, what messages did you receive? I cannot see those very clearly.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 27
KirillChepizhko
Reattaching the screenshots.
I reinstalled Fusion and it helped 😉 Just wanted support to pay attention to this issue. 7e6b9bcb608832626e3b7b80f7955460.png
Needless to say I didnt have any problems with internet connection or firewall or anything else mentioned
Message 4 of 27
masa.minohara
Thank you for sharing the information and I'm glad the issue is solved!
I'm not sure what caused it but I'll let you know when I find out.
Masanobu Minohara
Message 5 of 27
KirillChepizhko
having EXACTLY the same problem today again after reinstalling Fusion from scratch. When attempting to clear cache data and restart Fusion just freezes . So no, that didnt work
Application window is suspended on exiting the application
Message 6 of 27
KirillChepizhko
Attaching diagnostic files.
Message 7 of 27
KirillChepizhko
Just reinstalled ( without restarting pc) and the problem is still there. How do I clear cache and settings even after I uninstall the software ?
Message 8 of 27
Maowen_Zhang
On windows OS, you could clear browser cache at below location.
User folder (user local data):    %localappdata%\Autodesk\Autodesk Fusion 360
Browser cache:                       %localappdata%\temp\autodesk\BrowserCache
Web services cache:                %localappdata%\Autodesk\Web Services
Fusion 360 installed modules: %localappdata%\Autodesk\webdeploy
From the error message, the component (AdCefWebBrowser.exe AutoCAD component) doesn't work, it's used to handle browser/data panel on windows version Fusion. If this component is corrupted (missing or incorrect version), then it might report this error.
If clear browser cache doesn't work, could you please help to try below? I'm not very sure about the root reason, appriciate if you could have to take a try. Will check other team member about this further tomorrow. Thanks for sharing issue with us!
1. Verify no AdCefWebBrowser.exe running in task manager, exit if if have. Restart Fusion 360
2. If item 1 doesn't work, uninstall Fusion 360, then delete all contents in folder (%localappdata%\Autodesk\webdeploy), and then reinstall Fusion 360
Lori Zhang (Fusion Development)
Message 9 of 27
KirillChepizhko
Clearing out localappdata ( as recommended in clean uninstall) + removing webdeploy and reinstalling after that worked. Any idea how to prevent errors like that?
Message 10 of 27
Maowen_Zhang
Glad to hear you made it work now! Based on the log you shared, it seems the component "adcefwebbrowser.exe" was occupied and couldn't be updated.  I sent an email to related team members who will help to analyze this further to check the root reason. Thanks for sharing issue with us!
Message 11 of 27
KirillChepizhko
This keeps happening ! I am frustrated and dont know what to do anymore. No matter how I clean cache, no matter how many times I reinstall fusion from scratch - this problem comes back when I launch fusion. the only thing that helps for now is manually turning off adcefwebbrowser.exe in the task manager.
PLEASE HELP !
Message 12 of 27
innovatenate
Autodesk Support
Autodesk Support
Perhaps there is some interference from another application like anti-virus software on the system that is interferring with the adcefwebbrowser.exe process. Does this issue occur when the anti-virus (or firewall) software is disabled?
Nathan Chandler
Principal Specialist
Message 13 of 27
KirillChepizhko
It does look like a conflict with smth but I dont have any antivirus  or firewall. Could it be a router config ? I mean that is probably too farfetched..
But point is that a cloud based software probably should be immune to interference like that ?
I am clueless
Message 14 of 27
innovatenate
Autodesk Support
Autodesk Support
Are you staying on the same network or moving around to different networks? Are you using the default network preferences for Fusion 360?
Nathan Chandler
Message 15 of 27
KirillChepizhko
Yep, my screenshot looks indetical and I am on the same network all the time, cable straight to the modem. I dont have any other network issues
Message 16 of 27
kris_berg
Hi @KirillChepizhko,
We really want to get this issue resolved and get you back using Fusion 360.  I will be sending you a private message to gather some information and we may need to do a screen sharing session.  Sorry this has gone on this long without a permanent solution, but we will get you up and going.
Kris Berg
Fusion 360 Development
Kris Berg
Senior Software Architect - Autodesk
Message 17 of 27
innovatenate
Autodesk Support
Autodesk Support
I bumped into this forum post which sounds similar (thanks @saketsatta) and thought I would post it here in case it is any help.
In this case, switch the preferences to "No Proxy" helped resolve the issue.
https://forums.autodesk.com/t5/design-validate-document/fusion360-doesnt-start-properly/m-p/5970955#...
If you haven't tried this, could you give this a quick test?
Thank You,
Nathan Chandler
Message 18 of 27
KirillChepizhko
We have tried a bunch of things on the teleconference with Kris Berg from autodeks yesterday inclding no proxy and it didnt help 😉 Really curious what it might be now
Message 19 of 27
innovatenate
Autodesk Support
Autodesk Support
Sorry.. wrong link..
http://forums.autodesk.com/t5/design-validate-document/fusion-360-crash-on-startup-adcefbrowser-exe-...
Nathan Chandler
Message 20 of 27
kris_berg
Has the rolling back of the graphics driver fully resolved the issue?  If so, you could log a bug with NVidia and send them the dump file we generated last night.  I found the following link that might help you https://nvidia-submit.custhelp.com/app/utils/login_form/redirect/ask .
Thanks for being patient and supportive on this issue.  The screen shares were very helpful.
Thank you,
Kris Berg
Kris Berg
